Restoring a Honda ATC 200s
Old Aug 22, 2004 | 11:42 PM
BSmith's Avatar
Default Restoring a Honda ATC 200s
I Have a 200s that I am trying to restore...two problems...where can I find the pull start assembley for cheap ??, also how can I tell if it is creating a spark ???
another thing...do you really need the compression cable connected to the pull start assembly...is it necessary to have this thing hooked up ???
Old Aug 23, 2004 | 07:53 AM
mrtrikes's Avatar
to test for spark remove the plug, earth it to a clean unpainted surface on the engine and then turn the engine over and look for spark.The decompression cable will make it easyer to start.
Old Aug 23, 2004 | 08:33 AM
corvetteguy's Avatar
Honda NOS ATC-185/200 recoil pulley Item number: 2487348607
Watch this item in My eBay
Current bid: US $12.50
Time left: 13 hours
link
http://cgi.ebay.com/ebaymotors/ws/eB...category=35580[/S]
Old Aug 23, 2004 | 10:32 PM
BSmith's Avatar
Thanks...will look it up...thanks again
Old Aug 23, 2004 | 10:34 PM
BSmith's Avatar
thanks for the info...will try it again...did not earth it to metal surface...will try again...
can this bike operate without the decompression cable ???
Old Aug 23, 2004 | 11:35 PM
PlatinumDogg's Avatar
I would say yes, its only there to make starting it a whole lot easier...even tho i doesnt create that much compression to start with..i would say drop it unless u drive it in winter...then its a big plus to have
Old Aug 24, 2004 | 12:11 AM
BSmith's Avatar
thanks for the info..I think I will remove it because I cant get it connected in the pull starter assembly...I had to rebuild it and cant seem to get it hooked up...those starters are a real bear to put back together...even worse when the rewind spring comes undone.
on to the spark thing...if I cant get any spark...which part would you start replacing...I have two of these machines and will use one for parts (starter assembly down on both units).
any tips on how to keep the rewind spring attached to the pulley so that it doesent come undone when you pull the rope...
thanks all for all of your help
Old Aug 25, 2004 | 07:23 AM
mrtrikes's Avatar
try disconecting your on off switch when testing for spark ,it may be stuck in the off position.Also try another plug .Its best to start less expensive parts.
Old Aug 25, 2004 | 08:27 AM
BSmith's Avatar
Thanks..I will try disconnecting the on off switch...have already tried a different plug....thanks again
Old Aug 29, 2004 | 12:10 PM
BSmith's Avatar
hey thought I would fill you in...do have spark to the plug...was able to get it to turn over by having the kids push and popping it in gear...now need to get the pull start repaired and installed...should be able to get it started by adjusting th carb....
thanks again for all your help
scman843
Jun 18, 2017 10:21 PM
theddaug
Aug 15, 2015 09:17 AM
95wolv
Jul 17, 2015 08:13 PM
timster911
Jul 13, 2015 01:57 PM
