had to fix rear taillight wiring on 2003 trailblazer
Old Aug 26, 2004 | 01:40 AM
mistertinker's Avatar
Default had to fix rear taillight wiring on 2003 trailblazer
i had to fix my wiring on my 2003 trailblazer. put a L.E.D. 1157 bulb in the socket and it did not work. tried in my motorcycle worked fine. got out the test light and looked at the wiring. hard to believe but polaris ran the brake light wire to ground and the ground wire to the brakelight filament. a regular 1157 bulb works fine like this but a L.E.D. needs correct polarity. so i cut the two wires and respliced them correctly now regular and L.E.D. bulbs work correctly. guess they are all like this. a regular bulb does not care about polarity.
Old Aug 26, 2004 | 01:49 AM
mudmaster250's Avatar
so if i get the led from trailtech i cant run it? how exactly do u fix this?
Old Aug 26, 2004 | 02:04 AM
just in case you are interested in L.E.D. bulbs for your atv here is the place i got my bulb. also i have another link too. i plan on running extra L.E.D. lights on the front too in the future.superbright
l.e.d. tronics
Old Aug 26, 2004 | 02:10 AM
i did not see any l.e.d. lights on trailtech site. the advantage to l.e.d. lights are that they produce no heat,very low current, and no filament to burn out or break.
Old Aug 26, 2004 | 05:58 PM
scroll down and u will see it its like 5.95
Old Aug 26, 2004 | 11:44 PM
link does not work.
Chocobamofo
Jul 10, 2015 07:46 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
tweeder
Jul 5, 2015 01:57 PM
D-Hagz
Jul 4, 2015 02:19 AM
