Electric Start Help '82 200E
Old Aug 26, 2004 | 11:12 AM
cthomaswm's Avatar
Default Electric Start Help '82 200E
I can't seem to get my electric start to work. It clicks but no good. I thought it was the battery so I hooked up the charger/Starter to the battery and it sounds like something is bound up because it clicks and I hear a low hum like the starter is bound up. If I hook a jumper cable to the post on the top of the starter and hit the starter to ground it fires right up. I do have a pull cord and it runs fine but would like to get this to work. Is there a solenoid somewhere in line that could be messed up? Any suggestions?
Old Aug 26, 2004 | 03:43 PM
Lomax's Avatar
there is a solienod in there somewhere, cross it with a jumper wire and see if anything happens, if she fires then that could be the cause. Also there should be some fuses in there somewhere as well replace them. I changed out the solenoid on a 300 honda and it was just the fuse ( spent 35 bucks for nothing ).
Old Feb 7, 2006 | 04:40 AM
RedRider69's Avatar
Real Men Dont Use Electric Start.....Haha...But did you check to see if its a wiring issue?
Old Feb 7, 2006 | 12:25 PM
HondaAtcRoxz's Avatar
I think my solenoid is bad in my 300 too. Did yours stick on you sometimes?
4xrider
Apr 10, 2017 01:36 PM
Mikes350X
Nov 20, 2000 04:04 PM
rmx251
Sep 10, 2000 11:40 PM
Dom
Aug 3, 2000 08:04 PM
4trax300ex
Jul 29, 2000 11:41 AM
