tcs shocks help
Old Aug 21, 2000 | 09:18 PM
jbark35's Avatar
i have tcs conversion done to my works front shocks.it seems every now and then the front bottoms out on the frame .is there a way to adjust this or is there something wrong with the shocks thanks for any help
Old Aug 21, 2000 | 10:18 PM
hot_shoe_cv's Avatar
I run the TCS shocks with remotes. Im not very familiar with the conversions. Do you have remotes and have you adjusted the compression on them?
Old Aug 22, 2000 | 08:21 AM
400exalltheway's Avatar
yeah i have never even got near to bottoming out my TCS
Old Aug 22, 2000 | 10:39 AM
250R22's Avatar
I have tcs shocks with reserviors on a 250r with +2 a-arms and I have not botomed out my shocks but ihave botomed out my frame.
Old Aug 22, 2000 | 04:52 PM
jbark35's Avatar
ihave the remote resveror but the the adjustable ones i dont think the shocks are bottoming just the front of the frame is this normal
Old Aug 23, 2000 | 05:25 PM
JJFAT's Avatar
the reason i think your are buttoming on your frame is, because the shocks are adjusted too low. Tcs shocks are able to lower the ride height and maintain a reasonable travel. If i was you, i would call a realiable source to help you out.
Old Aug 24, 2000 | 04:39 AM
MX4LIFE's Avatar
I am running tcs on a 400ex and they are working great. You may want to call up TCS themselves and tell them your problem. They are really nice and more than willing to help out.
What type of front tires are you running.
If your MXing i hope they are grooved radials.
If you are not then you will easily bottom out your frame. especially on the preload into a jump if your hitting it at a descent speed. and that can be pretty nasty. To make a long story short,
Radial are where its at!! I would run at least 18 to 20 psi in them depending upon your rider weight. There is a reason why all the pros use them.
Old Aug 24, 2000 | 09:51 PM
jbark35's Avatar
i am using the mx radials im running 17psi inthem is there a way to adjust the ride height yourself thanks for the replys
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
