Valve adjustment & carburator question
Old Sep 1, 2004 | 03:51 AM
lovbyts's Avatar
Default Valve adjustment & carburator question
Yes I have dont tons of searching before asking these question.
I’ve been playing with my Raptor all day trying to get it to run 100%, no luck so far. I adjusted the valves at least 5x and had to re adjust the float levels. It still stumbles a little but instead of mid throttle it does it just a little now at the beginning. After adjusting my valves I still get a little valve tick. I followed the instructions to a T and re checked it many times. When I started there was 0 clearance. I set the intakes to 10mm and the Exhaust to 16mm. I adjusted, started it, rode it, let it cool and re adjusted many times but still get a little tick.
My main question is about the little clip with the O ring and spring that holds the needle in place and clips down in the 4 fingers that hold it in place. Does the O ring clip into place and that is all that hold it or does it push down further so the top outer ring clips into place down in the fingers? It seems awful loose if it is just the O ring that holds it in place.
Old Sep 1, 2004 | 05:35 PM
lovbyts's Avatar
No one has any idea?
Cole Hadden
Jun 15, 2025 09:05 AM
hondarider1234
Jul 21, 2015 11:53 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
MNatv89
Jul 7, 2015 11:36 AM
yambam13
Jul 4, 2015 01:49 PM
