DS650 stock 290Watt Stator
Old Sep 6, 2004 | 10:53 PM
ScoobyDFW's Avatar
Default DS650 stock 290Watt Stator
For those who are loading the charging system with accessories, be aware of the 290Watt limit on the stator. This is about 20amps total. If you're like me and wire in extra accessories directly to the battery each with there own fuse, then collectively all the electrics could exceed 20 amps without blowing any fuse!
My stator went bad this weekend most likely due to heavy current draw.
Electrix USA might have a stator with slightly more wattage. Also, the fuel injected BMW F650 has a 400Watt stator.
Old Sep 6, 2004 | 11:02 PM
CountryJoeGlass's Avatar
Scooby thanks for the heads up!
Old Sep 7, 2004 | 01:28 AM
Sandaholic's Avatar
Would a higher output stator such as the 400w one from the BMW F650 put more strain on the engine? Better question, would the strain be noticeable?
ultangler
Nov 30, 2024 01:35 AM
dannytas
Sep 26, 2017 06:31 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
