500 scrammy lookin' for more bottom end
Old Sep 7, 2004 | 01:26 PM
elgordo's Avatar
Default 500 scrammy lookin' for more bottom end
I'm lookin to add more bottom end to my Scrambler. I ride a lot of hills/jumps and am looking for more pop. Any suggestions? How about adding 1 0r 2 teeth to my sprocket?... Do you guys have any suggestions?...
Also, where can I find a larger sprocket?
Old Sep 7, 2004 | 02:10 PM
tbsleeper's Avatar
u can get a pipe and clutch springs or u can do a sprocket change. u want to go up in rear or down in the front for more bottom NOT up in the front down in the rear
Old Sep 7, 2004 | 02:24 PM
elgordo's Avatar
Thanks for the tip.
Old Sep 7, 2004 | 02:36 PM
BigBadScrambler's Avatar
If your scrambler is a 4x4 you can NOT change the sprocket sizes. Just pipe it and clutch it and you will notice the difference
Old Sep 7, 2004 | 02:49 PM
elgordo's Avatar
Thanks for the info. It is in fact a 4x4. I had no idea that I couldn't change the sprocket size... you saved me much expense and humiliation. Thanks, again.
Old Sep 7, 2004 | 03:20 PM
tbsleeper's Avatar
u could its just hte 4x4 wouldnt work right. so it looks like u will have to pipe and clutch it and u will notice the difference
Old Sep 8, 2004 | 12:09 AM
There are many options when it comes to exhausts. For a slip-on, you cant beat the sound, power, and price of the White Bros E-series. As for a full system, the HPD Powermaxx is the king. That and clutching combos are endless. I have mine setup to engage around 2200 RPM. I like it like that and am use to that setup. If you are looking for a low engagement, talk to ftwflh. He has his clutch set up so it has a lower engagement to a faster shift out rate. He has his set up to his riding style and is happy with it. But like I said, endless combos. You can also give Rick Ritter @ RCR a call. Tell him what you have and what you want it to do and he will put something together that will fit your needs. Rick is awsome to deal with
Old Sep 8, 2004 | 12:35 PM
nr's Avatar
nr
I have a 2002 Scrambler X.I purchased hottseat's $700 speed kit.( huge diffrence on bottom and top) If u want the most bottom end u need to buy a clutch kit and change the jettings. A pipe on a 4-stroke will not do much. It will be louder. Ur not going to be able to tell power wise. on a two stroke u can tell on both hp, and noise.
Old Sep 8, 2004 | 12:40 PM
elgordo's Avatar
Thanks for the advice! You've all have been very helpful. nr, Where can you buy this hottseat spped kit?
Old Sep 22, 2004 | 04:02 PM
elgordo's Avatar
Hey Big Bad Scrambler -
I spoke with Rick Ritter as you suggested and I ordered new clutch springs. Where can I find easy step by step instructions to perform the work? I'm not sure how to do it....
Thanks a million!
