air preasure in tire problem
Old Sep 8, 2004 | 11:04 AM
ekazmer's Avatar
Default Sportsman 500H.O 2004.05
Is it normal that on my 500h.o
since day 1 i need to put air in my tires every time? I always put 5 pounds. when i go to ride it the following week it is down to 1 or none. on all 4 tires. Should i go back to the dealer with this problem?
also how much air preasure is normal? in the book it says 5 just wondering what others put.
Old Sep 8, 2004 | 11:14 AM
elkbow's Avatar
Default air preasure in tire problem
They should maintain 5 pounds, but since you live in Quebec, is it cold when you are checking pressures? Is it cold when you fill the tires? 5 pounds is very low pressure and it will easily fluctuate due to temperature.
One thing I would suggest is that you are using a good tire guage. If all 4 tires are dropping pressures, that seems strange. I would take it to the dealer.
Old Sep 8, 2004 | 02:25 PM
BigBadScrambler's Avatar
It is not uncommon for tires (from all manufactures) to go flat right from the showrrom floor. It could be from a bead that is not seated all the way, or even dirt or debri in the bead area. I would take the tire off, pump it full of air, and submerge it in a tank of water and see where you are leaking from
Old Sep 8, 2004 | 06:19 PM
Polaris500HO4x4's Avatar
mine did that too ... broke the bead and reset it still did it so i just put tubes in them all. 32 bucks for tubes... i guess its better then havin to pump them up every time i go riding
Old Sep 18, 2004 | 02:14 AM
PhilFixit's Avatar
Mine too!
I just put 8 ounces of Slime into each tire, pumped them up to 8 - 10 psi, and swished the tire around until I got the Slime all round both beads (inside). (Obviously, you need to have them OFF the bike - Duh!)
Let them sit for a few hours, adjust the tire pressure, and go riding.
This cured my five to one pound overnight pressure drop.
Just about every tire shop has some black "bead sealant" that could be used in this situation, too.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
