A couple questions
Old Sep 17, 2004 | 10:37 PM
JohnCole's Avatar
Default A couple questions
My friend has a 250 Polaris Big Boss 4x6, and the model # is: W908627. He doesn't know what year it is or even have a manual for it. He said he was driving it slowly and it made a big pop and stalled and won't start again. It cranks over really easy by hand, so I did a compression test and got 100 p.s.i. That seems like enough to run. But I couldn't get the plug to spark, so I put a spark tester on it, and could only get a really weak spark. Does anybody have the same model? Obviously the plug is fouled, but why isn't there a nice fat spark? Weak coil? bad ground? Does anyone have a mnual with resistance tests for the coil and cap?
I didn't really even look at it, but does it need battery voltage to spark, or is it straight magneto? Any help or advice would be greatly appreciated, Thanks.
Old Sep 18, 2004 | 12:46 AM
scramblerXrated's Avatar
well at least i know that its a 1990 model. the first 2 numbers after the W is the year.
i would definitely lean toward checking out any and all of the ignition components. with compression like that it should run purty ok.
let us know what you find out!
X
Old Sep 18, 2004 | 02:38 AM
Polaris500HO4x4's Avatar
100 lb is a little low i would first get your spark goin strong, probablly a weak coil. check your SP wire too may have a short or pinch in it
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
gorylewis
27
Oct 4, 2015 05:22 PM
Anomers
Aug 16, 2015 11:06 AM
MNatv89
Aug 10, 2015 02:20 PM
