jetting to run
Old Sep 9, 2004 | 11:22 PM
yammaslamma's Avatar
Default jetting to run
hey, i need to rejet my quad desperately...and i kind of need some baselines...Right now as it is, it is running alittle on the rich side , and i have a 240 main with the needle and pilot jet stock.... after its warmed up sometimes it doesnt like to idle and if i ride below 5mph for long periods of time(like on rides following younger kids) it fouls the spark plug???
Old Sep 10, 2004 | 12:00 AM
also , i have another Q. what is the stock setting for the air mixture screw? i have that turned 1 and a quarter out too.
Old Sep 11, 2004 | 01:49 AM
anybody know the clutching or jetting set up? i am heading to nicholas cycle tomorrow.
Old Sep 11, 2004 | 03:54 PM
oghma's Avatar
I believe the stock jetting is a 240. I am running a 250 now, did have a 260 in but the same thing that was happening to you was happening to me. Now with the 250 the idle is still a little rough but that is just taking the time to adjust my carb. Right now I am running a 250 and the needle clip is set one down to the rich side. Havent fouled one lately but I dont let it sit there and idle either.
Old Sep 11, 2004 | 04:28 PM
tbsleeper's Avatar
i no the air screw stock is 2.5 out i think?!?! on mine. try taking it out 2 full turns and see how it is. and adjust the idle by turning the adjuster on the cable
Old Sep 11, 2004 | 04:32 PM
i guess i ddint know there was an adjuster on the cable??
could running too high of octane foul plugs? along with the problem of too rich? im heading down to nicholas cycle in about an hour and my shopping list is:
AAEN Green Primary
AAEN Blue Secondary
250, 260 Main jets
38 Pilot jet
EDIT: What is the gap set on the sparkplugs?
Old Sep 11, 2004 | 04:44 PM
tbsleeper's Avatar
for mine its .028-.024 its fouling because too much oil+gas at that part of the throttle.
wat u can do is let it idle and just tap the gas dont let it rev just let it idle hten turn it off quick and pull hte plug and see how it is. i just tuned my carb and its coming out as a tan/light brown
Old Sep 11, 2004 | 04:50 PM
just start it and let it idle untill it warms up to see if its running rich at idle
....well im still gonna go pick up that list of stuff. i turned the mixture screw 1 and a half out from stock and it didnt do it as bad but i could tell it was starting to as i was beginning to lose power towards the end of the day and theres still a dead spot in the range. i'm gonna have it tuned good once i get the pipe on there.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
