Sport Quads Discussions on sport quads.
need help with suspension
Old Sep 12, 2004 | 01:27 PM
brutis's Avatar
Default need help with suspension
What does it mean to pre-load your suspension? When do you do it and how do you do it safely?
Old Sep 14, 2004 | 05:07 PM
DC504's Avatar
do you mean adjusting the preload or preloading your suspension going through whoops and jumps?
Old Sep 24, 2004 | 10:50 PM
carguy07's Avatar
I always thought preloading your suspension was jumping down on the back end to make it go down right before you hit a jump.
Old Sep 25, 2004 | 09:59 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Stand up in the attack position, and lean on the front to compress the shocks as you hit the bottom of the takeoff ramp. As you near the top of the ramp, you will get some lift as the springs extend again.
Just in case you meant the other kind:
http://www.off-road.com/atv/suspension/shockadj.htm
Old Sep 25, 2004 | 12:21 PM
mucky's Avatar
the preload is how your springs on the shock are set up
it has to do with the weight of the quad and how it sits
when your on the bike. If the bike drops to low when riding and bottoms
out the shock alot than your preload isnt tight enough.
you want to be able to have full travel of the shock
thats what I learned from Elka Suspension
thats if your talking about adjusting your preload
Old Sep 26, 2004 | 11:27 AM
whitebroskfx440's Avatar
ohh right as i take off i just push down on my hole quad and they srping back up right at lip so you get a little more lift
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
