Buying used scrambler, which year(s)?
I might be looking for a used scrambler. Looking for a 400 4x4. What do you like/ dislike about scamblers between '98's- '02's. Like a pro's & con kinda list, or what they improved on this year kinda thing. Thanks for the suggestions. Justin
Prior to 1998 they did not have the concentric Drive system.
4x4 models had a Chain driven front axle vs shaft.
The Non concentric drive and Front chain drive was well known to be problematic.
So from there here are the updates:
2000 models got 2" more rear suspension travel and a 2 stage rear spring (Nice and soft).Late 2000 models also received updated HEIM style tie rod ends. (Previous Ball & Socket units are known to wear out fast.
2001 models got an updated braking package. (All steel braided lines, Drilled/slotted rotors, Better Reservoir assembly) Also Late 2001 models got and updated steering post, and lower support bearing. (Previous design had a riveted bushing that usually had play straight from the factory.)
2002 models got a life time belt warranty.
2003 models got a spliceless belt and also I believe polaris eliminated some of the grease fitting with LUBE FOR LIFE
toonces
Oct 16, 2019 12:11 PM
hoopduerr
Jun 10, 2015 03:00 PM
