Warrior bogging!!!
Old Sep 13, 2004 | 05:49 PM
YamahaRider05's Avatar
Default Warrior bogging!!!
My friend is having a problem with his Warrior (since he doesn't take care of it AT ALL). Me and two other buddies were looking at it for him, but could were stumped. All i could think of was the carb. Well here's the problem. It starts right up, but when you go into any gear and try to go, it bogs down and stalls no matter how much gas you give it. We had him clean the air filter and check his plug, but it still does it. Any advice would be very useful for him.
Old Sep 13, 2004 | 11:59 PM
04Raptor350Guy's Avatar
Maybe the jets are clogged.
Old Sep 14, 2004 | 12:17 AM
Doctorturbo's Avatar
GOT BOOST!
Put the choke on it about half way. If it takes care of the bog, see the above post.
Old Sep 14, 2004 | 04:07 PM
ill try, but it won't be til this weekend
Old Sep 14, 2004 | 05:38 PM
JakalWarrior's Avatar
*cough*parkingbreak*cough*
Old Sep 14, 2004 | 06:43 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
DEF A PARKING BRAKE PROBLEM!!!! down by the brake where the parking brake is make sure it isn't stuck out push it in...
Old Sep 14, 2004 | 08:17 PM
Rider1169's Avatar
i had the same prob with my bike, it would idle fine, but u couldnt rev it at all with out it dying, there was crap in the gas filter.
Old Sep 14, 2004 | 08:24 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Three things to check. With Mine I
1. Parking brake rev limiter on the clutch perch, fix i cut the wires
2. Grass seed in the main jet, Happend countless times, Im not sure how they got in there
3. Plugged screens on the petcock pick ups, pull it out and check it.
Sounds like a plugged main though.
Old Sep 14, 2004 | 09:30 PM
Im pretty positive that it isn't the parking brake because it never has worked AT ALL. The jet is probably pluged because his filter was so dirty that a seedling probably filtered through and went into the carb.
Old Sep 14, 2004 | 09:35 PM
Rider1169's Avatar
nononon, the parking brakes never ever really worked on thoe models, but htey have this annoying rev limiter that cuts the engine out real bad, and it sticks on a lot. i doubt its that tho, useually it wouldnt cause the engine to stall, just cut out and not be able to get gas. i bet something is clogged
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
