honda 400ex need expert help
Old Sep 13, 2004 | 08:18 PM
superevil's Avatar
Default honda 400ex need expert help
Ok,my neighbor wants to sell me a 01 400ex, as it sits it runs ok,but it ticks loudly and smokes blueish white(doesnt smoke bad).we adjusted the valves,but it still ticks the same. He told me he had over filled the oil,said someone told him to put almost 4 quarts of oil in it.Well after the valve adjustment,it still ticks and smokes,doesnt sound like a rod knocking,what do you guys htink is causing the ticking and smoking?
Old Sep 13, 2004 | 08:26 PM
RedEX's Avatar
Well, I'm no expert........ but I'll give you my 2 cents for what it's worth.
Mine ticks, my brothers ticked, heard others 400ex's tick - some more loudly than others - not sure what the cause is. I thought it was a problem with mine until I heard others and everyone said it was normal - I only notice it when I'm sitting on it.
As for the smoke - I'd guess it's the rings/piston, or could be just overfill on the oil maybe.
One of the gearheads around here should be able to help more - speak up boys (or girls) and help a bro out! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 13, 2004 | 08:31 PM
LynxLunatics's Avatar
ive owned 2, both ticked from the first day, as for the smoke, it may have been run hard at one time, a buddy of mine has one that blows whitish bluw pufss every once ina while. still runs strong
Old Sep 13, 2004 | 08:39 PM
superevil's Avatar
this one didnt tick when he first got it.you can clearly hear the ticking. I dont want to go spend money on a piece of crap.If the valves are adjusted right,what would be making it tick still. When your turning the crank through the side casing,to set the timing mark,every couple of rotations you hear a snapping sound,wich is most likely the sound we are hearing when started just faster. its a 2001 and he only wants 1200 like it is.but i want to have a good idea about whats wrong with it
Old Sep 13, 2004 | 09:00 PM
RedEX's Avatar
Hell, if it seems in good shape overall I'd give $1200 for it even if I knew it needed a piston.
Old Sep 13, 2004 | 09:02 PM
STLKR27's Avatar
sorry i cant help but that would be a perfect ex for me... since i dont want the ex motor, im puting my cr motor in an ex frame when i find one priced right
Old Sep 13, 2004 | 09:04 PM
95wolv's Avatar
Check to see if the timing chain is streched out, that can make a ticking or knocking noise, if it had a bad spot in it where the link was stuck, that could be what you hear turning it over by hand. You should be able to take the top cover off the side and check for play in the chain, then make sure the automatic adjuster is working, or if it is already at full travel.
Old Sep 13, 2004 | 09:05 PM
Derag2's Avatar
theres no way you can put 4 quarts in an EX......... The tank would be running over long before you got 4 quarts in there. I'd say the motor has seen better days.
Old Sep 14, 2004 | 02:46 AM
superevil's Avatar
yeah the whole machine is pretty beat,its a dang shame.im probably still going to grab it and fix it
Old Sep 14, 2004 | 09:45 AM
garyc660R's Avatar
If you can do the work yourself, you could rebuild the engine and do some cosmetic stuff. Still prob be under 2K total.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Asaran
Oct 8, 2015 11:14 AM
Huntingdeer
Aug 23, 2015 12:06 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
