need some advice, 450r cluster relocation!!
Old Sep 14, 2004 | 05:44 PM
bazerk125's Avatar
Default need some advice, 450r cluster relocation!!
First of all thanks for reading about my little issue! I purchased a set of Pro Taper 1-1/8 fat bars and some mounts. I would like to keep my ignition switch (somewhere) And my oil light. I dont think my tail light will work if I get rid of my ignition switch. Has anyone else had the same thoughts?, and if so where did you put these components. Any and all suggestions are greatly appreciated!!
Old Sep 14, 2004 | 07:20 PM
KGB's Avatar
KGB
I did exactly the same thing your talking about.
Drill a 3/4" hole in the side panel, just before the gas tank right side (sitting on it), you can mount the key there, it needs about 1-1/2" space behind it.
The temp light (not an oil light) can be mounted just behind the hood in the side plastic (so you can see it), you drill a 3/8"ish hole.Just look for a spot that will clear on the back. It will look clean. Mine looks like it came from the factory like that.
Old Feb 3, 2006 | 11:32 PM
blaster0315's Avatar
Old Feb 4, 2006 | 09:49 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
My Tag Metals bars came with a nice little aluminum plate that holds the ingition switch, temp light, and has a hole for the fuel tank vent tube. Should be simple to make one for any machine.
Old Feb 4, 2006 | 05:14 PM
scroll down and look a these handle bar clamps i think im going to order one of thosehttp://modquad.com/store/search_results.asp?page=7&txtsearchParamTxt=%2A&tx tsearchParamType=ALL&txtsearchParamCat=54&txtsearc hParamMan=ALL&txtsearchParamVen=ALL&txtDateAddedSt art=&txtDateAddedEnd=&txtPriceStart=&txtPriceEnd=& txtSale=&iLevel=1&subcat=54
Old Feb 4, 2006 | 05:16 PM
Text
Old Feb 4, 2006 | 05:18 PM
well link dont work just goto www.modsquad.com
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
