scrambler tires size
can i go 25" tires all the way around a 2004 i saw one with it done and he said it is fine hasn't had any problems i want to do some ITP c-series 12" type 6 or 5 will this be good with 25x8-12" on front and 25x12-12" bearclaws or mud-lites or even some 589's can i do this with stock suspension and hubs?? or will i have to go to 24" on the rear to keep the ratio??
Theroreticlly you should go with 1" smaller on the rear. Some have done the same size all around, but I would not recommend it. However, that is your decision. Depending on the tire lug depth, a 25" may rub the floor board on the rear. 24" shouldnt be a problem though. The fronts should not be a problem though.
