scrambler tires size
Old Sep 16, 2004 | 11:29 PM
ATKmetz71's Avatar
Default scrambler tires size
can i go 25" tires all the way around a 2004 i saw one with it done and he said it is fine hasn't had any problems i want to do some ITP c-series 12" type 6 or 5 will this be good with 25x8-12" on front and 25x12-12" bearclaws or mud-lites or even some 589's can i do this with stock suspension and hubs?? or will i have to go to 24" on the rear to keep the ratio??
Old Sep 16, 2004 | 11:38 PM
BigBadScrambler's Avatar
Theroreticlly you should go with 1" smaller on the rear. Some have done the same size all around, but I would not recommend it. However, that is your decision. Depending on the tire lug depth, a 25" may rub the floor board on the rear. 24" shouldnt be a problem though. The fronts should not be a problem though.
Bratman2
Aug 6, 2022 01:42 AM
MooseHenden
Polls
33
Aug 28, 2015 04:56 PM
rcappie4
Jul 18, 2015 07:51 AM
maxjung
Jul 13, 2015 05:11 PM
