tires for lakota sport
Old Sep 17, 2004 | 06:22 PM
Vunit's Avatar
Default tires for lakota sport
I was wondering if I put on Holeshots XCT 22-11-10 or razrs 22-11-10 (stock size rims) would the tires hit my battery box. I really don't want wheel spacers because it put strees on your axle and may cause it to break!!! Also what would you say is the best tires for wood riding again 22-11-10 stock rims!!!
Old Sep 17, 2004 | 07:23 PM
BANZAIENT's Avatar
Hey
For me the Holeshots XCT are the only way to go. I have them on my Mojave with a 330 kit and the traction is GREAAAATTT!!!!You can check my pictures and see if they will clear your battery box. I do not think you will have a problem with them.
BANZAI
Old Sep 17, 2004 | 07:48 PM
rolsmojave3's Avatar
hey BANZAIENT
you can get more power if you get rid of that airbox and just get a clamp on filter unless of coarse you ride in mud
just a suggestion
Old Sep 17, 2004 | 08:41 PM
BANZAIENT's Avatar
Hey rolsmojave3
Thanks for the suggestion. The inside of the air box is modified and the snorkle is off and the intake is opened up. I do ride in the trails alot with mud, water, etc.
Again thanks BANZAI
Old Sep 17, 2004 | 10:02 PM
Vunit's Avatar
Thanks Banzaient for the info, i'm almost sure that the tires won't hit the battery box!!! Also what psi are your tires set at!!! Thanks again!!! Another things is do you have an extended alxe!!!
Old Sep 17, 2004 | 10:49 PM
BANZAIENT's Avatar
Hey Vunit
I run about 6lbs in the rear tires. I run a stock with axle cuz I trail ride alot.
BANZAI
Old Sep 17, 2004 | 11:22 PM
Vunit's Avatar
Thanks again Banzaient, i'm going to look into some holeshots for my quad!!!
Old Sep 17, 2004 | 11:43 PM
clover's Avatar
Hey vunit we have two lakota's and one has gbc shredder 20x11x10 and the other has razr 20x11x10.Both of the tires rubbed the battery box,but doesn't affect anything,so if i was guessing the holeshots may rub also.
Old Sep 17, 2004 | 11:59 PM
Vunit's Avatar
Thanks clover, by the way how are the razrs, are they good all around and what psi are your tires set at !!!
Old Sep 18, 2004 | 04:42 PM
clover's Avatar
the razr's are great,they seem to be better than the shredders,i have 5 psi up front and 4 in the back.
