HELP! Electrical short? 99sprts500 after plugging into front accesory port.
Old Sep 17, 2004 | 08:53 PM
dwngreat's Avatar
Default HELP! Electrical short? 99sprts500 after plugging into front accesory port.
I plugged in a small power invertor into the front accesory port and blew something, my electric starter won't work or the dash lights or speedometer. I've checked the fuse under the seat and it's fine. Any help would be greatly appreciated.
Tim
Old Sep 17, 2004 | 10:13 PM
RevRick's Avatar
QUESTION? Was it running at the time you plugged the inverter in? Have you plugged it in and used it before?
Rick
Old Sep 18, 2004 | 10:51 AM
dwngreat's Avatar
Stupid me tried it running and not, and I've never tried to use it before. The 500 still starts with the pull starter but none of the misc electrical components work including the fan.
Any help you can offer will be much appreciated.
tim
Old Sep 18, 2004 | 10:28 PM
RevRick's Avatar
Hey Tim, I will look through the Service Manual tomorrow after church and tell you where the fuse and circuit breaker are located. But first question, is the battery at full charge? Second, is the stator still putting out charging voltage to the battery? You can check that by putting a volt meter across the + & - posts on the battery, read the voltage before you start it,....... then start it with the pull rope, and then check the voltage again at the battery terminals. If the stator is charging, and the regulator/rectifier is still good, the voltage should read about 14 volts.
Good luck, and let me know,
Rick
Old Sep 19, 2004 | 11:10 AM
dwngreat's Avatar
Thanks Rick, I'll go and check the battery and stator output this AM. I found the 2 fuses in the black plastic wrap, one under the seat near the battery (about 6 inches in front of the battery) the other under and behind the battery, seems to be just a connection for an accessory run off the back of the unit.
I hope there's a fuse or breaker somewhere else that I'm not seeing.
thanks again,
tim
Old Sep 19, 2004 | 01:24 PM
dwngreat's Avatar
Hi Rick, I did check the battery and it's fine, I did also pull start it and checked the output at the battery terminals and it registered 14.5 so it appears the stator and regulator are still working.
Tim
Old Sep 20, 2004 | 11:23 PM
dwngreat's Avatar
Hi Rick,
Did you ever get a chance to look up the wiring/fuse problem in the manual?
tim
Old Sep 20, 2004 | 11:39 PM
RevRick's Avatar
Tim, I sent you a PM (private message) with my phone number, give me a call.....OK?
Rick
Old Sep 22, 2004 | 10:17 AM
RevRick's Avatar
Howdy Tim,
Great talking to you, let me know how the test with the switch goes.....OK ?
Rick
Bigredjeep
Apr 10, 2020 02:55 AM
WilliamBos
Sep 30, 2015 08:08 AM
Mattius
Jul 11, 2015 10:44 PM
DOAinNY
Jun 11, 2015 10:34 PM
BigRedGrizzly
Jun 7, 2015 11:06 AM
