scrammy is bogging down in top end??
Old Sep 18, 2004 | 09:44 AM
quadracer18's Avatar
Default scrammy is bogging down in top end??
Well I went riding last night and when I get around full throttle (top end) it starts sputtering and doesn't want to go full throttle...the low range and mid are fine its just that top end.. I have a supertrapp exhaust and k &n air filter.. first thing that comes to mind is the main jet is a size to small...but ever since I had the quad its had those jets in it and the exhaust and filter....so what do you guys think?? to me it sounds like its the main jet but I just don't see why its been running fine with that jet in it for months and now all of a sudden its sputtering in the top end....if you think its the jet..what size do you think I need...I don't know what I have in there now. thanks
Old Sep 18, 2004 | 11:14 AM
yammaslamma's Avatar
soundds like the air filter is dirty
Old Sep 18, 2004 | 01:54 PM
BigBadScrambler's Avatar
The jet could be dirty too. Do you change/clean your fuel filter regularly? I would say that you probably have a piece of dirt or debri stuck in the jet
Old Sep 18, 2004 | 05:47 PM
racerX500's Avatar
I just had a prob kinda like yours. Turns out my secondary spring broke...
Old Sep 18, 2004 | 06:02 PM
tbsleeper's Avatar
could be alot of things!!! start wit a kinked gas vapor line, then clean the filter, then check the carb if all else fails check the clutches
Old Sep 19, 2004 | 12:03 AM
2phast4u2catch's Avatar
im having the same problem my dad said i need to rebuild my carb but it only does it if i wont warm it up enuff or am going full throttle in 6th after going from 1st to 6th i dont stop at ne other gear fer more then lik 2 secs cuz i ride w/yfz's and preds and z400's but im ordering a new filter and c if it helps and change my oil and then take my carb apart this winter
Old Sep 19, 2004 | 01:21 AM
Revshredd's Avatar
Had the same problem...changed the fuel fuel filter and put a new plug in and walah! problem was fixed. I might have also just lucked out! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 19, 2004 | 01:17 PM
Well I figured later on today I would check the filter...even though I just recharged it so I'm sure thats fine...I still think its the main jet...but I'll check some other stuff..I might just go spend six bucks and buy a couple new main jets at different sizes and see if thats it..but I'll do some checking on it..I still think its air/fuel problem..
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
