Wolverine Oil Cooler
Check ebay for one, or see if you can find a Big Bear or Kodiak cooler. The Wolverine is only a 3 pass cooler, the Kodiak and Bear have 5 pass, I found one off a newer Kodiak that is an 8 pass, while it will tak a little fabbing for the mounting, the oil lines bolt right on, and you will have more cooling capacity.
The oil lines will bolt right up, but you will need to fab some mounting brackets for the bottom, the top part will go into the stock rubber grommet, but you may need to put some protection on the bumper to keep sticks from hitting the bottom,since it will be taller than the stocker.Other than that, it is a bolt in, the width is the same, just takes a little remounting.
you can buy an oem one from yamaha.
try this link. http://216.37.204.202/yamaha_oem/Yam...e=13&A=184&B=2
I put the year in as 2001. this link is to change the year. http://216.37.204.202/yamaha_oem/YamahaATV.asp
