Wolverine Oil Cooler
Old Sep 19, 2004 | 12:27 PM
fordmustangfan67's Avatar
Default Wolverine Oil Cooler
I am in need of a Wolverine Oil Cooler. I have heard that Four Stroke Tech may have one? Anyone know for sure or have one?
Old Sep 19, 2004 | 10:13 PM
95wolv's Avatar
Check ebay for one, or see if you can find a Big Bear or Kodiak cooler. The Wolverine is only a 3 pass cooler, the Kodiak and Bear have 5 pass, I found one off a newer Kodiak that is an 8 pass, while it will tak a little fabbing for the mounting, the oil lines bolt right on, and you will have more cooling capacity.
Old Sep 19, 2004 | 11:30 PM
SpDdEmOn's Avatar
Yeah, Call Mickey at Four Stroke Tech. He knows what hes doing. (814) 842-6159 4-7pm eastcoast times
Old Nov 7, 2004 | 01:29 PM
Hookie's Avatar
95wolv,
Will an oil cooler from a 1998 Yamaha Kodiak 400cc work on my 2001 Wolverine????
Old Nov 8, 2004 | 12:03 AM
95wolv's Avatar
The oil lines will bolt right up, but you will need to fab some mounting brackets for the bottom, the top part will go into the stock rubber grommet, but you may need to put some protection on the bumper to keep sticks from hitting the bottom,since it will be taller than the stocker.Other than that, it is a bolt in, the width is the same, just takes a little remounting.
Old Nov 8, 2004 | 09:08 AM
1ShotScott's Avatar
you can buy an oem one from yamaha.
try this link. http://216.37.204.202/yamaha_oem/Yam...e=13&A=184&B=2
I put the year in as 2001. this link is to change the year. http://216.37.204.202/yamaha_oem/YamahaATV.asp
STLyamwar
Jul 25, 2020 04:44 AM
ronnierhino06
Nov 9, 2015 12:56 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
blessedn09
Aug 9, 2015 03:07 AM
metal249
Jul 24, 2015 01:00 PM
