warn winch problem
Old Sep 19, 2004 | 09:54 PM
squarehead1219's Avatar
Default warn winch problem
im new to the site.
anyways i got a 2.5 warn winch and i have nothing but problem with it, i burnt up one motor with in the first 5 months and I sent it back and warn fixed it. Last week i needed the winch to get me out of a big mud hole and the freakin thing didnt work. I took the motor end apart and found out it was all burnt up. What can i do about it and does anyone have this problem?[img]i/expressions/face-icon-small-confused.gif[/img]
When I installed it they tell you to put it lower the better, but if you have it to low it will get all muddy and wet
Old Sep 19, 2004 | 10:46 PM
spikeland's Avatar
problem sounds electrical.burnt motor sounds like too high amps or a short /ground problem.how is it wired ?through ignition.does it have its own inline fuse?you should blow a fuse before the motor burns up i would think.do the motors require lubrication?im no professional but those are the questions i would be asking. good luck
Old Sep 20, 2004 | 05:54 AM
Starky's Avatar
It definately sounds like something is shorting out. I have the 2000 and I was told not to wire it directly to the battery or it would burn the motor up. I wired it to the low beam on my headlights and it works fine. Whenever I want to use my winch I have to turn my light on first. With the light off, there is no power to the winch. Check inside your switch, maybe the wires are touching.
Old Sep 20, 2004 | 02:13 PM
UGLY88's Avatar
Mine is wired direct and I have had no problem. Mine is a Tusk, not a Warn though it should not matter. I have a circuit breaker wired in by the battery however.
Old Sep 20, 2004 | 09:36 PM
hey thanks,
mine is wierd right to the battery with no fuse.., ill have to do it different
thanks alot for the help.
Old Sep 20, 2004 | 09:47 PM
spikeland's Avatar
yeah if you wire it direct to the battery.definetly put an in line fuse on the positive wire.this should blow the fuse before damaging the motorif there is a problem.i once made the mistake of wiring a spotlight direct without inline fuse.i learned from that one.i ended up burning out all kinds of wires.
toonces
Oct 19, 2015 02:21 AM
Bratman2
Jul 23, 2015 12:36 PM
Gtsordo
Jul 22, 2015 01:27 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
