WET SANDING YOUR PLASTIC!
When your wetsanding your plastic what grit paper do you use and are there any tips you could give me. What do you use as a polish at the end. I have some deep scratches and this is my only choise now I think!
A few years ago, I remember a post from someone on sanding/polishing fenders, he said to start with a coarser one to take big scratches out, then work down to a 400 - 600 grit. When done, the plastic will be all white and hazy from sanding scratches,then you use a fine polish ( I think he recommended 3M Metal Brite,but others should work). Then use a buffer with a FOAM pad, cloth pads will heat up and burn your plastic, and buff until smooth. spray down with Son of a Gun or Armor All, wiped down, and it should shine real nice. I'm thinking of doing this to my quads this winter, summer riding is hard on shiny fenders with all the grit in sand and mud.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
