Raptor crankcase help??
Old Sep 20, 2004 | 05:11 PM
BigDylan's Avatar
Default Raptor crankcase help??
i was riding some local trails the other day and i hit a rock and it threw the chain of the rear sprocket and then it doubled itself up arond the front sprocket.
in the process it broke the upper mont for the casesaver off of the crankcase. i took off the casesaver and and epoxied the piece on. it was not good epoxy cause i rode the next day without a casesaver and i completely lost the piece. what is the best quick fix for this. i thought about epoxy(-ing??) some nuts onto the crankcase there or maybe even having them tig welded on. what is the crankcase made of?. i just hate hacking it together like that
where could i find another crankcase and for how much???
i plan on boring/stroking it after this winter so i will have to have the case split to replace rod and it should kinda easy to replace the crankcase that was broken shouldn't it?
any ideas? id rather not have to replace the case so i need help bad!
all help will be appreciated greatly
Thanks[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Sep 20, 2004 | 05:28 PM
pinheadedjoker's Avatar
I wonder the same thing.. i have just been riding without it..
Old Sep 20, 2004 | 06:21 PM
BigDylan's Avatar
so did yours break off too??
do you think it si okay to ride without casesaver
Old Sep 20, 2004 | 06:22 PM
sixsixT's Avatar
I'd just ride without it and fix it when you do the engine.
Old Sep 20, 2004 | 07:21 PM
how do you go about fixing it.. i still have one bolt hole where i can attach another one but what should i do tat the top?
Old Sep 20, 2004 | 07:53 PM
Raptorboy4life's Avatar
Hey guys.. the same exact thing happened to me. well.. a new case would run you about 180- at your dealer.. i ride without a case saver no problem. I could epoxy the piece back on if i want to but i dont really want to cause it wouldn't help to me. it actually reduces weight lol. I think your rappy will run fine... for future refrence you should switch from epoxy to JB weld or somthing like that. JB weld is a lot stronger then epoxy and it will hold on to aluminum very good. JB weld is mixed just like epoxy too so its the same abount of time you will be spending. if you really want the case saver back on... you can JB weld a little peice of steel with a hole in it and just run the bolt holding the case saver on lightly!!... with a nut. dont torke the bolt or the steel will fall off. ...... or save time and dont worry... sorry for the spelling mistakes!!
Old Sep 20, 2004 | 08:11 PM
maddog56's Avatar
Riding without a case saver on a raptor is just asking for an expensive repair job. You can probably get away with it for a little while, especially on a mostly stock machine. But you will need to address the issue before you do any major power mods to it.
bmxatv10
Oct 14, 2022 06:23 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
