Tire pressure on 400ex rears
Old Sep 21, 2004 | 04:05 PM
bullhoggrande's Avatar
Default Tire pressure on 400ex rears
What tire pressure do I run my 400EX rear tires when hill climbing in loose sand/gravel? Also, what tire pressure should I run a MX track with tight turns and alot of jumps. I can read the tire pressure on the side of the tire, but when I was hill climbing, I wasn't hooking up as good as everyone else, especially after a run got tore up. Any help would be appreciated.
Old Sep 21, 2004 | 08:44 PM
phibbsie's Avatar
4psi is what ur supposed to run the more you put in the more you slide and the less the more grip u get
Old Sep 22, 2004 | 12:19 AM
oldturtle's Avatar
I run 2.5 psi in the dunes, no jumping, just easy cruising around, and 5.0 psi every where else.
Old Sep 22, 2004 | 01:23 AM
nosliw's Avatar
they recommend 3.4 to 4.6psi i think so i never go too far either way
Bratman2
Aug 6, 2022 01:42 AM
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
metal249
Jul 24, 2015 01:00 PM
rcappie4
Jul 18, 2015 07:51 AM
