Exhaust Warp Thoughts,, Revisited
Old Sep 24, 2004 | 11:50 AM
Marylandatv's Avatar
Default Exhaust Warp Thoughts,, Revisited
Around the first week of August I put up a post to share my experience putting header/exhaust wrap on my quads exhaust system. Well after this past weekends hurricane ride and logging in around 5oo plus miles on my quad with the wrap, It was starting to look a little rough. I decided as I was cleaning my quad to take it off and maybe re-wrap it? The challenge with running wrap on an ATV is riding conditions. When the wrap gets wet it has a tendency to hold moisture in, Meaning rust and corrosion can set in on the pipes! Well I figured if I let the quad idle after riding in wet conditions or cleaning it, this would help in allowing the wrap to dry? Well in just a little over one month of riding rust and pipe corrosion has already started to set in on the pipes. With a good scrubing I was able to get most all of the rust/corrosion off, but my pipes are still fairly stained. If your running wrap I would give it a second thought BIG TIME! and like some had mention in the first post, after-market ceramic coatings are the only way to go if this is something your thinking about? Maybe even just leaving the exhaust alone in the first place?~lol. -coop
www.MarylandATV.com
Prairie 700
Team Green Plastic
Progressive Springs
OMF Beadlocks
Maxxis Big Horns
Dyna CDI
EPI Pink Spring/RED
Twin Air Filter
HMF Penland Exhaust
exhaust wrap
hot cams-on the way!
Oh and a Bunch of other Toyz
Old Sep 24, 2004 | 01:45 PM
rivermud's Avatar
I agree coop, unless its wrapped perfect it can also create hot spots and burn through the pipe. Went through that one already. Ceramic is more pricey but definately the way to go.
Old Sep 27, 2004 | 11:03 PM
KISSSOFDEATH's Avatar
Well, I know for a fact the exhaust wrap does reduce operating temps. The rust I guess can be a problem. Im not that worried though, when it does rust through I will go with the HMF full system. [img]i/expressions/face-icon-small-happy.gif[/img]
traumajunkie
Jul 23, 2015 02:10 AM
HondaR24
Jul 21, 2015 12:12 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
cSchwartz
Jul 12, 2015 07:42 PM
Mojave250A
Jul 11, 2015 10:38 AM
