just got a ds where do i check the oil???
Old Sep 24, 2004 | 10:40 PM
bigbird650's Avatar
Default just got a ds where do i check the oil???
i know yall are probly layghing but where do you check the oil thanks!
Old Sep 24, 2004 | 10:45 PM
DuneRider650's Avatar
I ride a little here and there......
On the left side of the quad up in front right infront of the handlebars behind the light there is a little black cap that can be unscrewed and the dipstick comes out and u can check ur oil.
Old Sep 24, 2004 | 10:50 PM
Prozack's Avatar
Congrats Big Bird.... What Dune Rider said!
One thing I might add is the flat rubber gasket/ring they use to seal the cap suck and lets oil seep out. Not too much but gets messy.... Replace it with a rubber o-ring and walaaa ! No more oozing !
Oh yea and it can be a pain in the **** trying to get the dipstick back in ... theres a small hole you need to get it through. I dont know if they changed that after the 2001s... probably not.
Have fun riding !
Old Sep 24, 2004 | 11:05 PM
nope its still hard to get the dipstick back in that stupid little hole.
Old Sep 24, 2004 | 11:11 PM
bigbird650's Avatar
thanks guys found it may if they put some hair around it i would have found it better lol anyways thanks again
OregonDunePatrol's Avatar
They could have made that plastic dipstick just a little taller so that it would be easier unscrew.
Old Sep 24, 2004 | 11:16 PM
yea its kinda hard to get at and unscrew im thinking about a metal dipstick i seen on the net somewhere..forget where but it was about half inch taller... it stuck out a ways.
Old Sep 24, 2004 | 11:20 PM
raidermike67's Avatar
When all else fails read the instructions<manual> LOL. Man, exact same thing for me I was like what the "blank" pulled out the owners manual, heck I thought that cap was for the radiator! Just an FYI, if you change your oil, make sure you drain the reserve tank in the front, I found this out the hard way, they don't even mention it in the manual but it holds like half a quart of oil.
Old Sep 25, 2004 | 03:07 AM
busmechanic's Avatar
the supply tank should have more like 2 to 3 quarts in it.
Old Sep 25, 2004 | 03:29 AM
XR650Warrior's Avatar
Come on now
