Recon making wierd noises
Old Sep 28, 2004 | 08:15 PM
428mustang's Avatar
Default Recon making wierd noises
When i hit jumps, me 2003 Recon ES starts to sputter., then dies. It starts fine, but it can only idle, and any more and it dies.It used to do this every once and a while, but now it happens here 30 minutes of riding. Its really getting annoying. PLease help, im trying to sell it and this really wont help.
Old Oct 4, 2004 | 11:53 PM
recon99's Avatar
My recon did that a few times before I rebuilt the motor. I think it's from overheating, but i'm not sure. This problem went away after the rebuild. Did you change your oil recently? If you didn't it could be causing more friction and heat, causing the overheating issue.
Old Oct 6, 2004 | 12:59 AM
428mustang's Avatar
I think that the honda dealer got it fixed, but how/ where did you get all that work done. i have been thinking about rebuilding it, but where do you get the stuff. also want to bore it, but thats a ways down the road.
Old Oct 6, 2004 | 12:17 PM
recon99's Avatar
I got mine rebuilt and worked on at a local powersport shop. With the top end being rebuilt and a new clutch I spent about $600, but it would have been less if my frame wasn't broken. All of the replacement parts except the clutch had to be purchased directly from honda, but my motor was getting to the point that the piston was flopping around inside the cylinder, and all the valves were completely shot. Yours being much newer, it probably wouldn't cost nearly as much.
Old Oct 13, 2004 | 09:49 PM
428mustang's Avatar
Turns out there was a bunch of crud in the main jet in the carb
greg74
Sep 10, 2019 03:03 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
MNatv89
Jul 7, 2015 11:36 AM
D-Hagz
Jul 4, 2015 02:19 AM
