1/4 mile drag
Old Sep 30, 2004 | 06:35 PM
DuneRider650's Avatar
I ride a little here and there......
Default 1/4 mile drag
hey all i might be going with a friend to a drag strip my quad is completely stock except for a modified endcap 14/40 gearing air filter and 22 inch tires............how do you think i would do against his piped banshee with tall gearing,raptors stock,not stock,both450's??
Old Sep 30, 2004 | 07:23 PM
Prozack's Avatar
Your kidding right ????? 1/4 mile drags ????? Against a piped & geared Banshee ????
Leave you DS in the garage and go watch.......... unless you switch the gearing to a 1 tooth over on the front. and maybe get a 38 or 36 tooth for the rear also!
With out better gearing youll be at the top of the RPMs in no time and watching them pass you by...
Even if you had the gears , youll have a problem with no horse power to pull em ...
Seriously , just go have fun and get some seat time... your at a disadvantage with your setup against the Shee but the other stock bikes itll be close if ya ride it right ??
Old Sep 30, 2004 | 08:03 PM
DCryder's Avatar
Yeah, get you some seat time......on the seat of your DS while you're going down the track!!!!!!!!
Prozack, why would you even tell someone to sit on the sidelines instead of having some fun??? NOT COOL!!!!
Put your stock 16 tooth sprocket back on and hammer down!!!!
You probably won't fair well against a modded Banshee, but I'd bet the 450's and Rappies will know you are there.
Old Sep 30, 2004 | 08:09 PM
Prozack's Avatar
Sorry ... I didnt mean maliciously ... What I MEANT when I said get some seat time was to get it on the DS like you said! But I F-ed up and didnt type it so I deserve that !
Whoops....[img]i/expressions/face-icon-small-blush.gif[/img]
But Im serious about that matchup with the shee, The DS would still be at the disadvantage and thats the brunt of my message.
Old Sep 30, 2004 | 08:18 PM
DCryder's Avatar
That sounds much better. lol
A lot of it depends on what pipes the shee has, if they're CPI or Toomey you will definately have odds against you. But with a lesser midrange type pipe you may be surprised!!!!
Old Sep 30, 2004 | 09:07 PM
my friend says his banshee with pipes does 80mph and well i can hit 83mph at the rev limiter and if i go back to 16 tooth on the front i cant hit 7900rpms i can only hit around 7400max and thats 84mph
Old Sep 30, 2004 | 10:45 PM
DCryder's Avatar
You shouldn't even be close to 83 mph with 14/40 gearing at 7900 rpms.
Best I can remember it takes 15/40 gearing with 22" tires and around 8300 rpms to get 83 mph.
But I may be wrong. LOL
Old Sep 30, 2004 | 10:50 PM
Well i did hit 83mph on my GPS and its bouncing off the rev limiter at 7900rpm's i got 22 inch bearclaws on the back and it barely pulls to 7900rpm with 15 tooth front sprocket but when it does its 82-83mph and with a 16 tooth front i cant even come close to pulling it i can only get about 7400rpms................................... i just did some 1/4 mile drag racing on a highway i marked off the distance with gps the best i could get was 17 seconds and my speed was 76.8mph
Old Sep 30, 2004 | 10:51 PM
MY MISTAKE.........i got a 15 tooth front not 14.....
Old Sep 30, 2004 | 10:52 PM
mudnuri's Avatar
Let us know what happens
