400ex compression reliese on cam Help
Old Oct 4, 2004 | 11:25 AM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Default 400ex compression reliese on cam Help
My brother called me today and said he put a stock cam in his 400ex and fired it up and it ran fine then when he went to adjust the valves he went past top dead center mark and had to turn the motor backwards. Now it will not run ? it will fire but will not start .He told me in the manual it said not to do this or it will ingage the compression reliece but the manual does not tell you what to do if you are dumb enough to do it. If anybody knows what to do please let me know.
Old Oct 4, 2004 | 10:10 PM
anlicer's Avatar
RELEASE
Old Oct 4, 2004 | 10:35 PM
oldturtle's Avatar
Just start over again. Turn engine counter clockwise until you are at TDC on compression stroke. You do not have to be exactly at the "T" mark. Close will do. Just do not turn clockwise. Then adjust right front exhaust valve which should now be too loose.
Old Oct 6, 2004 | 11:23 AM
Tpsycho's Avatar
Old turtle YOU ARE THE MAN. Thank you for your help we did what you said and it fired right up.
Thank You Very Much.
Old Oct 6, 2004 | 02:34 PM
cals400ex's Avatar
if you were running an aftermarket cam, make sure you added the spring and plunger back into the head if it was removed for the aftermarket cam. also, don't turn the motor over backwards. just go and make a complete revolution. remember, you need to be on the compression stroke too.
Scooter's Shop
Oct 9, 2015 02:09 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
