Stock Bore with 11:1 Comp.
Old Oct 6, 2004 | 12:39 PM
Zeakman's Avatar
Default Stock Bore with 11:1 Comp.
I just ordered a wiseco piston. I got stock size bore with 11:1 compression but i got .010 over rings. Im going to has my cylinder machined smooth and im goin to file the rings down to fit perfect. I had Stock piston and comp. before do u think i will notice the power difference now that its goin to be 11:1 instead of stock. I also got new valve seals so the compression should be all there. what do u guys think. I have K@n filter w/ no lid and WB R4 exhaust.
Old Oct 6, 2004 | 01:48 PM
Speedbump's Avatar
Zeak what quad is this for? If it's the LT you'll probably notice a slight improvement just because your current setup may be gettin tired. I dont think you should file your rings, instead have your cylinder matched. This is the proper way. I personally would have went with a higher compression because the gains are more significant. Also while you have your motor apart you should have your cylinder/head ported/flowed.
If this is for the 400ex in your pics I dont think the 11:1 will net any noticable increase. Return it and get a 12:1. Also look into a cam setup. Hotcams are an inexpensive option that will definatley give you good bang for the buck. Also consider going to a 416. It will only cost you a slight bit more and the difference is night and day.
dannytas
Sep 26, 2017 06:31 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
