sprockets combinations?
Old Oct 6, 2004 | 04:05 PM
trentk's Avatar
Default sprockets combinations?
does anybody know from experience what spocket combinations i can get without changing my chain.i was thinking maybe a 17-38 setup?
any input is appreciated
Old Oct 6, 2004 | 06:02 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
17-40 should work - you will have to take some material off the case saver. And you will need some good power for a 2nd hear launch.
Old Oct 6, 2004 | 09:11 PM
trentk's Avatar
do you drag race your quad.? im starting to set mine up for drag racing. you got any tips?
Old Oct 6, 2004 | 10:01 PM
Prozack's Avatar
17-38 will work and thats about the limit. Next youll have to remove links in the chain. If your running 18 or 20 in rear tires that should be fine for 2nd gear launches but if you run 22s in the rear then what ANNIHILATER says is true about needing extra HP. If your going to run the drags mostly then you might want to think of going another direction with your gears like a 15 - ? combo.
Theres plenty of guys on the board that mostly drag.. listen to them they know their sh&t.
You might want to list your mods and perhaps what kind of drags your getting into Sand, Dirt, Asphalt? Is it 300ft drags 1/8 mile ?? or just for bragging rights with your buds?
Good luck...
Old Oct 7, 2004 | 04:58 PM
trentk's Avatar
2003
full ron woods pipe
ron woods cdi
jetted
dynojet kit
future plans
carbon fiber clutch
boondockers nitrous
tm 45 and ported intake
then maybe high comp piston
im going to drag it at marion county drag way. pavement
cams and valves, and springs
buddieboy
Dec 9, 2016 05:50 PM
Sep 30, 2015 01:37 AM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
