oil change
Old Oct 6, 2004 | 09:21 PM
devocorky's Avatar
Default oil change
i have a 86 350 honda fuurtrax and when i chnged the oil i put the filter in backwards...has anyone ever done this and how long would it take to damage the valves with no oil up there. Im a dumbass and not worthy to own a quad.
Old Oct 6, 2004 | 09:34 PM
BS400EX's Avatar
Default oil change
You have put it on correctly NOW right?
Old Oct 6, 2004 | 09:41 PM
devocorky's Avatar
Default oil change
Yeah, when i changed the oil last i ran it for a bit up and down the road and parked it until today when i started to look at it. And now when i start it the valves are ticking.
Old Oct 6, 2004 | 09:44 PM
devocorky's Avatar
Default oil change
And get this, when i bought the quad the oil pump was shot and i had to replace the head, rockers and cam. Very pricy!! Now i think i have did it again!! I am pissed. I wonder if i can adjust the valves to quiet them if they are not that badly damaged.
Old Oct 6, 2004 | 10:17 PM
BS400EX's Avatar
Default oil change
I'm Sure you could adjust the valves if you are a decent mechanic (I don't know what your skills are). Buy a repair manual if you don't already have one. That will help you adjust the valves at least.
Old Oct 6, 2004 | 10:22 PM
devocorky's Avatar
Default oil change
I will get the mech. to do that i have done enough damage. I cant believe that filter does not have any markings on it for direction.
Old Oct 6, 2004 | 10:28 PM
BS400EX's Avatar
Default oil change
What brand of filter was it? Most of them are marked "This Side Out" on the plastic end of the filter.
Old Oct 7, 2004 | 01:51 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default oil change
A few people have done this over the years. If the valves are ticking, I would say you have scored the cam. Adjusting the valves might help for a while, but I bet you have lots of other damage.
Old Oct 7, 2004 | 03:47 PM
devocorky's Avatar
Default oil change
I believe the brand of filter was emgo?? It was from royal dis. All it said was " top" Whatever that means. does "top" point in or out?? Well now i know its not in. I guess it doesn't take long to do damage. All over a 3 dollar filter. Man i'm pissed.
Old Oct 7, 2004 | 07:35 PM
PINKMOON's Avatar
Default oil change
Sorry to hear about your mistake . I would take it in and tell the service department what you did and have them check it out. You may get away with a simple valve adjustment...or you may be into it for a little more. At least you will know what needs to be worked on for sure. That way you will have the piece of mind knowing that all potential problems have been dealt with.
Good luck.
PINKMOON
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
