Gas leak
Old Oct 8, 2004 | 03:06 PM
SPARKY4Q2's Avatar
Default Gas leak
im having problems with my drain hose leaking fuel. the hose under the float bowl, if i let it set for a while gas will start running out of it? why is that? i think its coming out when im riding to? how do i fix this problem![img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 8, 2004 | 03:20 PM
DuneMe's Avatar
Default Gas leak
Your floats or the float valves are sticking.
Pull your carb off and the floats may be sticking or the valve the floats push up may be sticking.
Pull the thing apart and clean with carb cleaner.
Old Oct 8, 2004 | 03:22 PM
Freakneh's Avatar
Default Gas leak
Something is making your floats stick.... Sounds like it's time to clean out your carb...at the very least the bowl.
Old Oct 8, 2004 | 03:35 PM
SPARKY4Q2's Avatar
Default Gas leak
thanks guys ill give that a try! it seems to run ok though? ill soak everything down and see what happens.
Old Oct 8, 2004 | 04:11 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Default Gas leak
Make sure you check your float adjustment while you are in there it could be they are out of adjustment.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
