warrior rear brake messed up help
Old Oct 8, 2004 | 06:12 PM
MOJAVE02's Avatar
Default warrior rear brake messed up help
well i replaced the brakes the other day in my 01 warrior rode around they worked fine. i thought to myself why not bleed the brakes while im at it so i loosened the bleeder screw and pumped the foot brake up and down and fluid came out and once it started coming out kind of heavy i tighted to screw up. after that the rear brake pedal pushes all the way down and does not work one bit. i tried adjusting the brake it has brake fluid i cant figure it out. what did I do wrong? did i bleed it right? help here please guys.
Old Oct 8, 2004 | 09:44 PM
2FAST4URASS's Avatar
well fill ur res back full of brake fluid and then get some one to assist you get them to pump the brake leaver up and down bout 10 times then on the 10 th time hold it down and then you break the bleader screw loose and then retighten and just keep doing this it will work p.s be sure they dont let the brake pedal go till you retighten the bleed valve again it again hpe ya get it [img]i/expressions/face-icon-small-happy.gif[/img]
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Cummins Driver
Sep 11, 2019 01:22 PM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
