81' 185s
Old Oct 8, 2004 | 06:25 PM
SDATVER's Avatar
Default 81' 185s
I gotta 81 a85s and i know it needs a new throttle cable and im planning on doing a lot of work to it but it runs kinda eratic and i was looking is it normal for the choke plate to kinda bounce a round. Or do i need a new spring for it can anyone help thanx
Old Oct 9, 2004 | 01:59 AM
KNOWSALOT's Avatar
The Facility
Default 81' 185s
The choke valve should remain where it is selected at all times. If it's moving around on you, first check to be sure the pin that engages the notch on the lever isn't bent or that the lever is worn out. Then look on to see if the spring is broken. The spring is there to ease the release of the choke valve, but doesn't keep it in a fixed position. The pin and lever do that.
Regardless of what you find to be the culprit, Honda, nor Keihin offers any replacement parts for any portion of the choke workings on these carbs.
You will have to get some pieces from a salvage yard carb or manufacturer your own fix for it.
superdizzyboi
ATC 3-Wheelers
Aug 30, 2015 07:22 PM
fourtraxmike
Apr 28, 2005 01:53 PM
robg
Mar 21, 2001 09:05 PM
63tbirdrick
ATC 3-Wheelers
Jan 22, 2001 07:50 PM
garyc660R
Oct 25, 2000 10:59 PM
