04 rancher 350 starts hard...
Old Oct 13, 2004 | 11:22 PM
quicksilver's Avatar
Default 04 rancher 350 starts hard...
my owner's manual says to put the warmed up idle speed at 1400 +/- 100 rpm, but when i set it this high it starts hard when cold. i put the choke on and dont touch the throttle, but it just seems to fire a couple times and i have to crank it for a while before it will finally start and run on its own. anybody else have this problem? i'm wondering if the idle mixture is not right...
oh yeah, one more thing, the air has been about 40-50 degrees lately, if that means anything...
Old Oct 20, 2004 | 10:09 AM
fredbear92's Avatar
Hello quicksilver.Ive also got the o4 es 2x4.Mine is a bear to start below 60-65 degrees.But on the left side of your carb,there is a primer bulb.Similar to lawn mowers.Mine has to be primed three or four times and then apply the choke to start.Give this a try.Ive never owned a honda before and polaris doesnt even have a primer bulb.Scott.
Old Oct 28, 2004 | 08:51 PM
trailtick's Avatar
hello i have a 04 350 rancher i pull the choke turn on the switch and push the throtle one time about 1/4 and it fires right off.
neilbedwell
Nov 10, 2018 11:02 AM
Marc Parish
Jun 26, 2015 09:37 AM
ROWALKER
Jun 15, 2015 05:38 PM
RedRancher
Jun 4, 2015 12:29 PM
1000gade
May 27, 2015 12:37 PM
