removing shifter and reverse?
Old Oct 18, 2004 | 04:59 PM
scramblered's Avatar
Default removing shifter and reverse?
that the only few thing i plan to do next season,does it worth it?
i want to throw out that shifter,cauze my tranny need new gasket and i'll need to open up it anyway.
is the non-reverse gears make a differences in the tranny?
cauze i known some up here have done the thing,please let me known,thanks,happy riding.
Old Oct 18, 2004 | 08:13 PM
OneBadPolaris440's Avatar
your really not going to feel a difference ... If you want to loose weight off your quad it would help .... I ride at the dunes and I never use it so i just got rid of it ... Austin
Old Oct 18, 2004 | 08:16 PM
But your not going to be able to take out your shifter tho .. you still need it for nuetral, and you cant just take out the reverse ... you have to put a spacer in to replace it ... its confuzing
Old Oct 18, 2004 | 08:19 PM
tbsleeper's Avatar
watta u use for a spacer
Old Oct 18, 2004 | 11:12 PM
mudmaster250's Avatar
most likely to keep the gears aligned inside the tranny. just take the linkage off and find something light weight and make a shifter that comes off the tranny. thats what i did.
Old Oct 19, 2004 | 02:55 PM
thanks mudmaster250,i found your idea on the same way i'll doing it,
i'll make a custom shorter shifter to fit the thing better, thanks.
Old Oct 19, 2004 | 03:40 PM
Whitedog's Avatar
The reverse gear weighs around 4lbs. And you gotta figure that is all rotating mass.
4lbs less that your motor and tranny have to spin. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 19, 2004 | 04:34 PM
tbsleeper's Avatar
mudmaster u tried to tell me something i alreadyt no i was asking wat did he use for a space
Old Oct 19, 2004 | 06:22 PM
if u want pics i can prolly get them on sunday and have them up sunday night. it still needs to be painted but it looks nice.
Old Oct 19, 2004 | 06:33 PM
Bradracer18's Avatar
It looks tacky(but you can redesign something off of this to make it look better)....but I once had to use a wrench to shift mine, right on the top of the gearbox.......you could make something right there to decrease weight. Also, just tear into the gear box, that is about the only way you are going to understand how it works, and how to make a fix for it. I would take out reverse and neutral(or the componets to get it in).......if that is possible.
