General 2 Stroke top end rebuild question
Old Oct 19, 2004 | 08:58 PM
EastTexasBoy's Avatar
Default General 2 Stroke top end rebuild question
I just got my 20 over Wiseco Piston Installed on my 01 Trailblazer and i got a lot of slack side to side when the piston slides on the wristpin is this normal? I sure dont want to buy another cylinder if it pukes PLEASE HELP FAST!!!!!!!!!! James
Old Oct 19, 2004 | 09:02 PM
Ernie660R's Avatar
Thumb of rule for piston the cylinder wall clearance is .003 to .005 thousands. Sounds like you might have more. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Oct 19, 2004 | 09:19 PM
Snowwolfe's Avatar
Sounds like maybe somebody bored out the cylinder before you or you have the wrong sized pistom. Have you measured the cylinder?
Old Oct 19, 2004 | 09:28 PM
OH! yall misunderstood or i just didnt explain myself good enough I dont have the cylinder on yet and i was checking the piston moving it side to side on the rod without the cylinder on ! James
Old Oct 19, 2004 | 09:51 PM
99WarriorCustom's Avatar
Without the cylinder on you will have extra play thats fine. If it is still there when the head is on then there is a problem
Old Oct 19, 2004 | 10:00 PM
I know the bore is right I took the piston when i had it bored I just didnt know how much play i should have with the cylinder off!! Thanks James
Old Oct 19, 2004 | 10:08 PM
Bradracer18's Avatar
Are you talking play between the piston and wristpin(the sliding back and forth slack?)???? If so, it is supposed to move, but I don't know how much. This should have nothing to do with you cylinder, by the sounds of it........should have to do with you wrist pin, piston, and the little C-clips that hold the piston on.......
Cummins Driver
Sep 11, 2019 01:22 PM
kelleycully
Sep 15, 2016 02:57 AM
Big bousse
Sep 26, 2015 10:42 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
yambam13
Jul 4, 2015 01:49 PM
