someones knocking
Old Oct 20, 2004 | 12:12 PM
jimraelee's Avatar
Default someones knocking
Hello all,
Well I think I know why I got a good deal on my 350 4x2.. after it warms up seems to get a knock to it... definatly comming from the cylinder area... but the funny thing is unlike a car engine where the knock gets worse with RPM/load this seems to go away... any ideas???
Old Oct 20, 2004 | 12:56 PM
RAJ's Avatar
RAJ
I could be the piston slaping, do to a broke off piston skirt. If you can get it cheap, have it bored out and put a new wiseco piston and rings in it.
Old Oct 20, 2004 | 02:14 PM
hawleywood's Avatar
take the clutch cover off and listen to the clutch as it is running thought i had a knock in the motor but is was just the clutch making all the noise
Old Oct 20, 2004 | 08:05 PM
2manytoys's Avatar
I can tell you that what you are hearing is the primary clutch knocking.You will notice it more at idle. All Polaris autos do it. It is the slide buttons on the primary that is worn down so the clutch knocks. The buttons are about 4 bucks and it takes 6 of them. It will stop the knock but it will eventually start again. Many people dont pay attention to these but that is the famouse Polaris knock. Not a big deal. It wont ruin anything. It can just be annoying.
Old Oct 20, 2004 | 08:49 PM
ftwflh's Avatar
Take the drive belt off and see if it still makes the noise if not you NEED to get the buttons replaced before they wear out the slides.This happened on the Scrammy I just got.Clutch was wore too bad to rebuild so I had to get a new one.Major $$$$$$$
Old Oct 21, 2004 | 12:44 AM
jimraelee's Avatar
will these buttons make it dificult to get into gear... mine has issues right now and its tough to make it into high low and reverse... not every gear works in the knotch on the shifter piece... well I removed the cover to the belt drive... removed the belt still made nosie.. but if its in the cytrifical clutch assy then taking belt off wont help much... cause the clutch is still rotating when I started... I even reomved the little 3 little paw cams inside and it still rattled... so Im pretty sure its in the piston /crank assy.. I guess off to the dealer for pricing
Old Oct 23, 2004 | 03:21 PM
jimraelee's Avatar
ok.. anyone hav a clymer manual... Im looking but not seeeing exactly what you mean??? well I removed the cover to the belt drive... removed the belt still made nosie.. but if its in the cytrifical clutch assy then taking belt off wont help much... cause the clutch is still rotating when I started... I even reomved the little 3 little paw cams inside and it still rattled... so Im pretty sure its in the piston /crank assy.. I guess off to the dealer for pricing
jdunne01
Oct 4, 2015 10:29 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Irishman301
Sep 23, 2015 01:47 PM
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
