350X motor into TRX250X
Old Aug 31, 2000 | 03:19 PM
Homegrown's Avatar
Has anyone done this swap? Am I just looking at motor mount changes or are there unseen problems with this swap?
Thanks in advance
Old Aug 31, 2000 | 04:53 PM
novaman15's Avatar
my dad has a 87250x with a 86350x motor in it. he did it back in 87 when i was only 3 so i'm not sure how he did it.
Old Sep 1, 2000 | 12:00 AM
radgumby350's Avatar
i know you have to notch the frame for the head to fit into the bike. i think you have to turn the carb to the side a little bit for the cable to work ok.
where did you find the motor? i am looking for one!
good luck!
Old Sep 1, 2000 | 02:30 AM
THEXOTIC1's Avatar
You will also need to get a custom head pipe cause the stock 250x pipe is too short. or i have seen people weld on an extension to the stock 250x pipe. You will also have to mount an oil cooler for the 350x motor..
Old Sep 5, 2000 | 09:01 PM
trx270r's Avatar
The contact is powroll racing they make a conversion kit that comes with a pipe. you can also use a 350X swing arm and shock, but you must add spacers to the swing arm to pivit point. There web site is Http:\\www.powroll.com .
Old Sep 6, 2000 | 01:56 AM
rhino99's Avatar
Why dont you put the motor in a 250r chassis instead of the 250x. The chassis for the 250x is not high preformance like the R. Cant get long travel suspension or anything. I just know if I were doing it, it would be better to go with the R.
Old Sep 14, 2000 | 07:51 PM
87_250R's Avatar
you should check e-bay for a engine i see them there a lot. take your time and do every thing right and you will be happy later.
Old Sep 29, 2000 | 04:21 PM
krabill's Avatar
I have a 91 250x with an 86 350x engine in it, it makes the bike have more torque, but I am not really that impressed, it will out run 300ex's other 250x's and mojaves, thinks of that sort, but I believe a 400ex would take it all around, if you got money and time and are bored then go for it, think about your oil cooler though, its a b1tch trust me, later
Old Sep 29, 2000 | 06:27 PM
dtalbott's Avatar
This is a great conversion. The 350X motor can be punched out to a 460 kit for under $1000. Also, for long travel suspension, put the 400EX front end on it (400EX a-arms and shocks). That works great and is cheaper than you might think.
Been there, Done that.
See Ya,
Darrin Talbott
Pehter
Oct 3, 2024 11:00 PM
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
