WIRING
Old Oct 21, 2004 | 12:19 AM
podrag's Avatar
Default WIRING
Anyone have a simple wiring diagram for just the essentials to start and go. No lights, starter, engine temp, fan, etc.
Old Oct 21, 2004 | 05:52 PM
mudmaster250's Avatar
Default WIRING
im not quite sure but i know that to get power to the ignition with out the key u have to take a wire from the positive battery terminal to teh solid red with a white stripe wire in the ignition switch. run the wire from the battery and quick splice it into that wire first then try it and see if it works then u can start to take things off.
Old Oct 21, 2004 | 11:54 PM
Whitedog's Avatar
Default WIRING
Ive got nothing on mine except, for the ignition part of the stator, the 3 wires that lead from that to the cdi, and the coil. I also run a mechanical temp gauge. And use a 12v cordless grease gun battery to run my tach
Old Oct 22, 2004 | 12:35 AM
Default WIRING
but how did u do it though
Old Oct 22, 2004 | 12:54 AM
Whitedog's Avatar
Default WIRING
Schweew... its been many months, and miller lites ago since I did it. I think the charge coils are screwed to the stator plate. I just removed them and pulled the wires out of the harness. pluged the 3 prong plug from the stator back into the cdi, and ran the blue wire from the cdi to the coil. Theres also a brown wire from the stator that needs to be grounded.
To shut it down, put a switch in the black wire (cdi) that will ground to the frame when closed. The blak wire is also where the tach hooks
I think this is rite, but id have to look to be sure.
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
