Shift Linkage Problems and Fix for 03 Kawi 650KVF
Old Oct 23, 2004 | 09:39 PM
bogtrotter's Avatar
Default Shift Linkage Problems and Fix for 03 Kawi 650KVF
My Ride was jumping out of high gear on the fly after 0nly 650 miles since new, but it was OK in Low and Reverse. Turned out to be the shifter linkage adjustment. Shifter linkage settings also affect the high gear engagement depth. See the Tech Tips on Nyroc's site (www.atv.dsnalias.com) for the method of adjustment. Also I filed a small concavity, with a 1/4" round file, on the detent rack (black plastic piece just below the shifter handle). I made the concavity just a tenth of an inch deep and did the same at all detent positions to preserve symmetry. I filed it right behind where the shift lever rests on the flat spot in each position. That concavity stops the shifter linkage from jumping out of postion under heavy acceleration on a bumpy trail. Note: After the detent is filed adjustment of the shifter rod length will be necessary, but also be sure to check the front engine mounting bolt for tightness before you start this.
hondarider1234
Jul 21, 2015 11:53 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
