Oil leaking from the front drive shaft of my p650
Old Oct 24, 2004 | 08:40 PM
Xrxman's Avatar
Default Oil leaking from the front drive shaft of my p650
Has anyone replace the bearing and seals on the front drive shaft of a p650?? Does any one have a service manual that could share this procedure out of. I hate to take my bike to the dealer if i can do it myself. Is this difficult to do or is a dealer the best way to go.
Thanks for any help
XRXMAN
Old Oct 25, 2004 | 04:47 PM
Maddog20E's Avatar
are you referring to the front drvie shaft on the rear of it where the shaft goes into the "pumpkin" . that seal there??
Old Oct 25, 2004 | 05:27 PM
moosin's Avatar
is ti the propellar shaft (the shaft coming out of the front of the engine into the front diff) if so its very easy just pick up the service manual and follow the instuctions if you have any more questions just post it up hear again and ill see it or someone else whos done it will good luck but it is pretty simple once you get in there.
Old Oct 26, 2004 | 07:38 AM
Xrxman's Avatar
The seals arent going tobe an issue but the bearing in the front differential also need to be changed that were my fun starts.
jayking232003
Dec 4, 2019 09:38 AM
txkevin
Sep 21, 2015 02:02 PM
traumajunkie
Jul 5, 2015 03:03 PM
D-Hagz
Jul 4, 2015 02:19 AM
Mphillips
Jul 2, 2015 07:20 PM
