Help with my Mojave
Old Oct 24, 2004 | 10:39 PM
Gump91's Avatar
Default Help with my Mojave
I am new on this site and wanted some help with my 1987 Kawasaki Mojave 250. My dad bought it for me for my birthday. When I got it was running fine, until after a while it started to have white smoke coming out of the muffler pretty bad. Everybody I talked to said it was just burning oil and that it doesn't hurt to run it like it is. Well today it started running bad; it sounded as if it was about to cut off on me. Or like it was starving for gas. But it wasn't, the gas was turned on w/ a full tank of gas. We pulleds the spark plug and cleaned it and it still wouldn't start. Are their any suggestions with what I should do?
Old Oct 25, 2004 | 11:51 AM
rolsmojave3's Avatar
go to kawieriders,com with a . instead of a , for a lot of help on it
Old Oct 25, 2004 | 04:51 PM
Gump91's Avatar
I tried going on that sight and it didn't work
Old Oct 25, 2004 | 05:32 PM
summitlt's Avatar
The site is www. kaw ie rid ers. com witout any spaces. For some reason that site is forbidden to write, but if it will help you...
Old Oct 25, 2004 | 05:46 PM
sugarhead's Avatar
What color smoke was it blue,black or white?What did the plug look like as for condition of the insulator on the plug.Did you guys try th basics like new fuel,proper oil level,make sure carb is lean an jetted right an a compression test an spark test,is the coolant level at the proper level an not using coolant.?
Old Oct 25, 2004 | 05:49 PM
sugarhead's Avatar
I misread your post,It sounds to me ya blew a head gasket,if your oil is milky white it could be that or the water pump seal.I dont know the damage it could range from anything to bent valves ,blown rods an wiped bearing to complete engine failure from all of these.Sounds like time to get amanual an break that mtor down.good luck
Old Oct 25, 2004 | 07:32 PM
Gump91's Avatar
I am only 12,so I don't know much about the unit, but what my dad did was only do a spark plug clean. The spark plug was very fouled. we cleaned it very thouroughly. And we also tried to start it by him pushing me in gear and it would barely run then cut off. The guy we bought it from said he would take it apart and find out what it was and fix it.
Also the guy said it could be possible that the combustion chamber is filled w/ oil and won't get a spark.
The color of the smoke was white. It was burning oil so bad that little drips of oil was on the muffler. But everybody I talked to said it was fine to run it like it was.
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
RidE
Oct 19, 1999 06:10 PM
dunc_n
Aug 26, 1999 09:32 PM
BlackHawk
Jul 31, 1999 01:31 AM
