03 raptor transmission problem?
Old Oct 26, 2004 | 07:52 PM
codestir2's Avatar
Default 03 raptor transmission problem?
I'm getting a slow tick when I ride and it sounds like it is coming from the transmission. It only ticks wile in gear and moving. Motor is fine and it rolls without a sound. Somebody please help. The faster I go the more it ticks and I need to know whats wrong with my baby.
Old Oct 26, 2004 | 08:27 PM
maddog56's Avatar
I'd put my money on the chain or sprocket hitting something. Check your rollers, case saver, sprocket tabs, etc.
Old Oct 26, 2004 | 10:58 PM
codestir2's Avatar
thanks man I appreciate it I'll chick it out tomarrow and see what I can find. But one more question. If I hold the clutch while stile rolling I get no sound. Is it possiable that I warped somthing but it only is afected when the motor is pulling?
Old Oct 27, 2004 | 05:27 PM
maddog56's Avatar
You may want to check your shift linkage, as it may need adjustment as well. Could be adjusted tight on one end of a shift.
Old Oct 27, 2004 | 08:29 PM
rutelis's Avatar
i had the same type of sounds comin from my 03 raptors tranny....the raptor has a default starter and the starter gear gets stuck and grids....thats what mine was doing...if urs clunks and makes all werid noises when u start it and after u start it it did it on mine when it was running, it might be it....when its doing it quick press in the starter button and let go and see if it stops...if it does then its probly ur starter....i got a L&A bearings put in mine and it runs great and starts good
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
bikedad3
Jul 2, 2015 02:15 AM
