big bore banshee??
Old Oct 27, 2004 | 12:20 AM
1wildshee's Avatar
Default big bore banshee??
I have a 1998 banshee and am thinking of going to a big bore (68mm) what all do you have to do besides getting your cylinders resleeved. I have a cool head with 18cc domes on it now, do they make big bore domes for a pro design cool head, or do I need em???
Old Oct 28, 2004 | 12:21 AM
1wildshee's Avatar
bump
Old Oct 28, 2004 | 01:55 AM
DaBeechMan's Avatar
why do you want to go to a 68mm bore?
Old Oct 29, 2004 | 10:02 PM
1wildshee's Avatar
well I have a set of cylinders that already have big bore sleeves in them but they need resleeved. I can resleeve them myself. I was just wondering what else I have to do. I have 18cc domes now on a 64.5mm bore 54mm stroke and have 172psi. I want to stay around 175psi. Do you have to go to a big bore dome?? I have heard that when people do this they have to get there head rechambered to accomidate the bigger bore.
Old Nov 2, 2004 | 12:00 AM
1wildshee's Avatar
anyone have one of these???????
Old Nov 2, 2004 | 07:12 AM
enFORCER's Avatar
Check out Vito's web site, I believe he has Big bore domes for the Pro design cool head....
Old Nov 2, 2004 | 11:44 AM
Hiram's Avatar
On big bore you will need to run big bore domes or have your stock head's squish band cut to match the new piston diameter.
Old Nov 4, 2004 | 06:41 PM
Chrin's Avatar
should i get a banshee or 400z
Old Nov 4, 2004 | 07:17 PM
Heapster's Avatar
I ran the Vitos 68 mm 404cc big bore kit for a couple years.
+4" swing arm extension is a must, otherwise you're always pointed skyward.
My motor never ran hot even with the stock head. I was running 380 and 400 mains in it for jets. Yes Vito redomes your cylinder head to match the flame front and shaves .060 or .080 off. I was only around 155-160 psi, so could run premium pump gas fine.
If you've got some spare cylinders that need re-sleeving anyways, go for it!
PM me with an email address and I can send you some pictures showing the 68mm Vito Power Piston and dome reshaping.
Mine was pretty fast and dyno'd at about 58 horsepower, but I think a good port job and a 370 kit may give you a higher reving power due to lighter pistons. I went through a set of Vito pistons a year too, so keep that in mind with their shorter skirt you get more piston slap. $200 a year for pistons gets pricey after a couple times through the motor.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greek271
Aug 8, 2015 08:16 PM
