Jetting question for Raptor
Old Oct 28, 2004 | 06:57 PM
Raptorman690's Avatar
Default Jetting question for Raptor
Ok, I got an 01' in the process of rebuilding. Instead of doing a 690, I am just going to go with a 10.5:1 compression, with my White Brothers Slip-on. I wanted to know what main jet and pilot I am going to need for it???? Also, i dont' know if it matters, I am doing the 4 degree keyway from Vito's Performance. SO, any help would be great.
Thanks
Old Oct 28, 2004 | 07:36 PM
maddog56's Avatar
Degree key? On a raptor? Why?
You cant know for sure what mains you will need. Stock needles may be ok, it depends on your air filter setup.
Old Oct 28, 2004 | 07:47 PM
With the degree key from Vito's performance, you pick up at least 2 HP. My air filter setup is kind of a custom setup. I have only seen a handful of these, and they are mostly on Banshees. I have the front part, (where the carb boots come into it) cut out, with two thin wall aluminum tubes coming from the boots, into two round K&N filters.
Old Oct 28, 2004 | 07:53 PM
maddog56's Avatar
You will be the second person I've ever seen run a degree key.
Your pilots and needles should be ok but you may need a couple sizes bigger for the mains.
Old Oct 28, 2004 | 07:58 PM
What is so wrong with the degree key?? I mean, is it going to cause problems?? I am rebuilding it right now, or here this next week, and I am doing the valves and all that, so is it going to cause problems??
For $20, to pick up 2 horsepower, tell me it isnt worht it?
Old Oct 28, 2004 | 08:03 PM
maddog56's Avatar
I havent tried it personally so I cant say. I will say that no one else seems to be running them, so there may be something to that. It was my understanding that timing changes didnt help performance much on a raptor unless you are running funny fuel.
Old Oct 28, 2004 | 08:05 PM
Almost every single person that I have met that owns a raptor, with any type of mod done to it, pepe, piston, intake, etc.... has had a degree kit put on it. Once all of those things are on and in sync with eachother, it runs like hell. Fast as hell too......
Old Oct 28, 2004 | 08:24 PM
Bosch's Avatar
This is the first I have heard of a degree wheel for a Raptor,,,or for any four stroke at that. Where can i get info & specs on one of these things,,,
Bosch
Old Oct 29, 2004 | 06:24 PM
Here is the website.................: Vitosperformance.net, you might have to e-mail them for the specs, the specs they show are for the banshee.
Click on online shopping, then raptor, then scroll down a bit and you will find it.
Thanks
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Jul 22, 2015 06:01 PM
yambam13
Jul 4, 2015 01:49 PM
