2005 E-ton Viper 90R
Old Oct 29, 2004 | 12:05 AM
DCRNA's Avatar
Default 2005 E-ton Viper 90R
Can anyone please tell me how to adjust the cdi or which wire I need to cut to make the bike run better?
Thanks in advance.
Old Oct 29, 2004 | 11:38 AM
moonRider's Avatar
DCRNA - Take the seat off, next to the battery there is a black box withe wires coming out. This is the CDI...Lift it out and turn the yellow dial 0-7..Factory setting is 4.....Not much of a change going up...
Hope this helps!
Mike..
Old Oct 29, 2004 | 11:48 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Thanks in advance.
Ready for mods? Lot's of people here to help with suggestions.
Old Oct 31, 2004 | 06:15 PM
DCRNA's Avatar
I have looked there with no luck............anybody else know where the wire is that you cut to make this bike run faster?
Thanks
Old Oct 31, 2004 | 06:16 PM
DCRNA's Avatar
I did turn the box up to 7, but it didnt make that much difference.
Thanks
Old Oct 31, 2004 | 06:42 PM
newnick's Avatar
There is no wire to cut on the 05.
Old Nov 19, 2004 | 07:45 PM
CRFBoy99's Avatar
I can't even find the CDI box i see the battery and sum wires coming outa it then there is like this little space that is right next to the battery and it looks like sumthing is supposed to go there but there is nuthing there
Old Nov 19, 2004 | 10:27 PM
moonRider's Avatar
CRFBoy99 - Only the reverse models CDI are under the seat....The others are in the front of the quad..
Remove the front grill
on the right side under the fender you will see the black box.
It's held to the frame by a rubber mount.
Good luck...You wont see much of a change turning it up....Need some engine mods for that..
flyin-lowe
Dec 1, 2017 03:18 AM
salixair
Nov 3, 2015 08:25 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
